2nd Battery Question
the end that is screwed to the car (the ground ) unhook it from the car . hook up another 0 ga wire to the neg post up front run the wire from there to back by where the ground cable is now loose . you can crimp another oring to the new wire and screw them together or you can take the oring off and use a coupler. you want to insulate the coupler or the 2 orings just to be safe. then see if the alt charges the back battery good with the sound system off. should start to go up after a few minutes and hold the charge
Could I just measure the resistance of the grounding point on the main battery to the grounding point in the trunk? Because in order to do what you said I need to buy 15ft of 0 gauge.
i have also heard that even with the same potential that with the ground being at a different location that it acts as if the rear ground is in a different circuit, because its not grounded to the frame. never really thought about it i just knew that if it didnt work in the back just do everything at the battery
If your alt is a 140amp adding a second battery will not help. The charging system must be able to charge at the same rate that power is being consumed.
Also your wiring from the alt must be sized to meet the new demands. A 10ga wire is not going to cut it. I run a 1/0 for power and ran a 1/0 ground from mine.
only needs to charge at an average rate which is greater than the rate at which power is being consumed on average.
if you keep the volume down overall but play it loud for short periods of time a 140 amp alt can "support" 10k rms with enough batteries
You mean Watts being consumed not volume being turned down. Remember a Watt is a Watt!
That 140amp alt only has a 30amp overhead to run all the add on stuff. HU, Amps, Lights etc...
When you crank it up the alt is going to running your system and has nothing left for charging your battery. It's at this point your car is running off the battery now.
10k watts is 695 amps at 14.4 volts, you better have a 400 amp bttery charger in your trunk!
My big 3 was done months ago lol.
I MAY have found the problem....I went and removed the back panel and stuck my hand down by the battery to see if anything was loose and the ground was completely disconnected....
the727kid
the727kid
St. Pete, FL
the727kid
