I have a Diamond Audio D61500.1 powering 2 TDX 12"s and an Alpine MRV-540 powering 1 set of Rainbow Contours(components) and 1 set of Alpine Type-R(components). HU is an Eclipse CD8455. I have done the Big-3 in 0gauge. I have 0gauge from the stock battery(fused at battery under hood) all the way back to the Yellow Top in the trunk. 0gauge grounds for both batteries. 0gauge to the distribution block then 2-4gauge(1 per amp) to the amps. Each amp having a 4gauge ground to chassis. This is all in an 01' Nissan Maxima.
Issue time, I have noticed a steady drop in voltage at idle w/o the stereo on. When the system was first installed, everything was 14.4-14.5 at idle. It now won't go any higher then 11.5.
I am currently a student and have limited funds. I am assuming I need to replace the batteries. They are about 11-12months old. Should I bother with an isolator? If so which one would you suggest for my set-up? I would love to get a 200amp alternator but can't afford it and also the stock alternator is still under warranty. Maybe next year I will be able to fund that project.
As of today, bass response falls off dramatically with higher volumes. I obviously can't have that. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I hope I have provided enough information to aid you in helping me. Thanks for your consideration.
