26,000 watt lanzar amp
If this amp is the same as the cactus 12k, which based off the images it is, then at MINIMUM i'd say it's good for 12k, if not more.
The opti series is very good stuff and usually conservatively rated.
Besides, i'd rather pay that much for an opti than for some banana and coffee bean filled amp that when it breaks takes a year to get fixed.
i agree
interesting always thought the opti line was good just thought this had a odd ratting ... it is the opti 12,000 1d for i would assume it could do the rated 12k or prty close to it good info!
those #'s still dont add up....lol
4100x2@2ohm typically is identical to 4ohm mono power (amp sees same technical impedance) but it somehow gains 5000 or so watts by being in 4ohm mono over 2ohm stereo....hhmmmm ....**** Koreans cant even make up numbers that mathematically add up for their garbage amps.. VERY VERY skeptical it is even an amplifier.. I think its either a bathtub or a clothes hanger or a blender...
I like Lanzar's Opti series and people over at Termpro talk good about them all the time, however the specs seem weird...
# 2 x 1340 Watts RMS @ 4 OHMS
# 2 x 2400 Watts RMS @ 2 OHMS
# 2 x 4100 Watts RMS @ 1 OHM
# 1 x 13,000 Watts RMS Bridged @ 4 OHM
# Maximum Power Output 26,000 Watts @ 1 Ohm Stereo
If it does 2 x 2400 watts @ 2 ohms stereo then it should do 4800 watts x 1 @ 4 ohms mono, but it's listed to do 13,000 watts @ 4 ohms mono. Maybe the specs are listed wrong?
Vegeta, what does the scouter say about its power levels!?!!???
//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif
12,000wrms....????
680A external fuse rating / 6800wrms MAX!!
12voltz+-
12voltz+-
lorain OH
psychoacoustics
