250A fuse enough for 1/0 AWG?
It does. You always want to underfuse rather than overfuse, unless you like fires.
Don't listen to this guy, he either has no idea what he's saying or he's just trying to be a smartass. What would be the purpose of putting in a fuse under the necessary rating?
The only thing that changes with a HO alt compared to a Stock alt is the amperage output. If your going to run 0 ga wire to your big 3 then you need to add a 300 amp fuse, thats close to what a 0 ga wire is rated for, a 350 amp fuse wouldn't hurt but it's not necessary. If your planning to do competitions then skip the fuse, but if your just building up your street system then play it safe and add the fuse.
Just curious as to why you wouldnt need a fuse on a competition setup? wouldnt you want it in case you get a short?.
Aloha
Nope, you'll never see serious competitors running a system with any fuses. Look at it this way, your running a single run or multiple run's of 0 ga wire, think of how thick this wire is. Now look at the largest fuse you could buy for this wire, compare the size of the wire and the size of that tiny little strip of metal in the middle of the fuse. Your cutting down on the flow of power from the battery to the amps. If your running your amps for music your not pulling as much power from the batteries and you'll never know the difference, but when your competing that fuse can make the difference between 1st place and 4th place, who really want's to lose.
So 250A fuse won't work? I NEED 300?
Basicly, with a stock alt will that wire ever be seeing more than 250A, I don't think so, so in my mind 250 is fine...Is that bad logic?
Nevalite
Nevalite
Canada
mazzasec
