SOLD 240 1/0 Ring Terms, 7-Way active crossover, Indash Voltmeter and Wire/Acc
j3bus2k3
Si vis pacem, para bellum
6,712
St. Pete, FL
Ok, I've been long out of car audio but this **** didnt sell at a swap meet and needs to go...
-First off, "uncommon" indash tsunami voltmeter. gives xx.x readout of voltage as well as fuse status for up to 4 fuses. Fuse indicators are blue IIRC, and readout is red. $50
-Second, is another uncommon or rare item; a Coustic XM7 7-Way active crossover. Adjustable gain, freq and Q for front and rear. High pass, band-pass mid and band-pass low with independant level control for High Mid and Low. Badass little unit. Never used it myself, good condition. $100
-Third, 240 1/0 ring terminals and 94 4awg terminals. Bout awhile back and was using them for my projects and customers, but I'm out of the game and these are useless. ALL SOLD
-Remainder of JL Audio Wiring Kit. 14' Red 2Awg Primary, 3' 4Awg Ground, 17' Monster 2-Ch RCA, 13' Remote and an extra 1' 1/0 battery ground. $60.
Also pictured is an 18' stinger 4-ch RCA. $10 extra or seperate, NOT included with JL kit.
Random Crap:
-Inline Knuconkeptz 1/0 fuseblock with 250A Fuse SOLD
-Box wiring terminals; accept up to 12awg wire. $2 (Free by choice if you purchase something esle)
-12" Subwoofer Rubber Gasket/Rings SOLD (Free by choice if you purchase something else)
-Knukonceptz Ground Distribution block. I never installed it but it is used. SOLD
-Speaker Rubber gasketing. Used for behind the basket to seal against the wood. $2 (or again, free by choice if you purchase something else)
Want this stuff gone. Prices are negotiable but I'm not even gonna reply to ludicrous offers. Thanks Guys
Bump for a good seller!
How long have you had the Coustic? Also, does it come with a power connector - or does the power wire attach directly to the unit?
I had it a number of months before I left for the marines. As far as I know, it does need a power connector, but the girl at coustic said she'd mail me one for free...
Probably ~18 months and been collecting dust for the entire time
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
Had a set of Ecplise 6x9's back in the day in my '99 Grand Cherokee. The SE8495s iirc those were so sweet sounding. Wish I hadn't sold the GC with...
I have never heard SP Audio. From what I have sampled, it seemed that the DB Arnolds sounded the most detailed. Then again, they were auditioned...
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
j3bus2k3
j3bus2k3
St. Pete, FL
j3bus2k3
maylar
    Jun 2, 2024
    Jun 1, 2024
