2015 Jeep Cherokee
mml
The Cherokee has an Alpine "upgraded system".
Dash has 3 x 3.5"
Front and rear doors are 6x9's
Rear pillar 2.5"
Sub - 8" DVC
All channels are 2 ohms.
Apparently the amplifier has some sort of DSP built in, I'm not sure if this includes time alignment and other important functions similar to after market DSP's that I have read about.
My question is, if I add amplifiers with higher power through high level for each channel would the sound quality improve, my thinking is that the factory DSP functions would still function but with better/cleaner power.
I want to keep rear speakers (passengers).
the simplest anwer is yes, more power ususally means better speaker performance, which amps do you have?? the dsp that amps have are usually for xover functions not time aligment
Taken from from last vehicle, Alpine PDX-1.1000 and PDX-4.150, I realize these do not have hi-level in.
I'm not sure if I want to try a JBL MS-8, or add higher powered amplifiers with hi-level in, if the speakers have issues I would then upgrade them and if required add the MS-8 to tune everything. I'd like to do it in stages.
Taken from from last vehicle, Alpine PDX-1.1000 and PDX-4.150, I realize these do not have hi-level in.I'm not sure if I want to try a JBL MS-8, or add higher powered amplifiers with hi-level in, if the speakers have issues I would then upgrade them and if required add the MS-8 to tune everything. I'd like to do it in stages.
another quiestion do you like a "plug and Play" or do you like to play with setup? plug and play ms-8, play with set up, bit one, mosconi 6 to 8 with this you can have a new world with your current amps and speakers
"plug and play", I don't have the time to "tweak"
I don't mind buying new amplifiers if required.
And then upgrading speakers if amplifiers are added.
I was hoping to start with amplifiers for each channel, or an MS-8, followed by speakers....
Whichever you choose to do, I am here to support you with product, advice and instructions. I can help you to connect MS-8 to the factory amplifier. For your information and others with a Jeep Alpine premium audio package, it's not simple to interface to this amplifier due to the number of channels. Changing some or all of the speakers is highly recommended for the best results so you don't have some speakers out of sync with the others.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Not less power but less channels. Maybe upgraded all around Bose speakers as well.
I may end up buying the new CDT ES-08 Plus and running customspeakerpods.com 8" speaker pod.
23
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
mml
mml
ottawa, canada
trumpet
