2014 Ford Taurus SHO SQ stealth Audio build
customaudioman
Will be starting a SQ audio build on a new 2014 this week. The Taurus will retain the stock Sony
navigation unit to keep a OEM unit look and feel. Will be running fully active 2 way up front and a sing 12" sub in the rear. The trunk area will house the DSP processor, amps and sub in a stealth setup to maximize space for daily use and clean OEM look.
The equipment and products
- Mosconi 4to6 DSP
- Mosconi Gladen one 120.4 amplifier
- JL JX 1000/1.
- PHD FB 6.1 Pros 2 way components
- JL Audio 12w6 v2 in sealed enclosure
- Focal BAM X.X.X.L Sound deadening material
- Black hole sound tiles for door panels
- Stinger 100% copper 14ga speaker wire, 4 gauge power wire
- Stinger RCA cables
Stay tune for updates
Love the new SHO's. Wondering why you went with a JX amp though? The rest of the equipment is in a much higher class than that amp. Just odd to see a Mosconi and a JX series in the same install
That's the amp the customer is supplying me with for the install. It was out of his budget range to add a new Mosconi amp for the sub. If it was up to me it would be all Moasconi AS amps.
Car got here today, but had to wait a few hours for Ups. Here is all the equipment laid out.
Here is the interior dash photo.
You are full of ****.. You have a focus. Mommy's car isn't yours.
Subbing to see progress.
In short, I agree, however one could argue that the term "mine" could be applied in the situation of it being owned for a family. Such as my house, I don't pay for it, I live in it though. I don't pay for my mom's car, but I ride in it almost everyday.
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
809
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
customaudioman
customaudioman
everywhere
customaudioman
    Jun 1, 2024
    May 31, 2024
