2011 Chevrolet Impala
gckless
Figured I'd start this now. Before I say anything more, I am going to start with this disclaimer: this build is going to be slow, but then really fast. I can't put one component in without having the rest. So, it's going to be 2-3 months of designing, planning, and procrastinating, and then it's all going to come together in a week's worth of work (hopefully). I'm only starting it this early to hopefully get some help/tips/thoughts to help me see something I may not have.
Now that that's out of the way, here she is:
The Blazer was having problems, ****** was making noises and starter was starting to go and I didn't trust it to drive out of the city. It legitimately was the biggest source of stress in my life. Threw in the towel, got the car. Got tint done this weekend too.
Here's what I pulled out of the Blazer. All of this will be transferred to the Impala:
For my head unit, it will be an 80PRS. Just ordered the dash kit, wiring harness, and antennae adapter. I really hope I can get the voltage meter in the pocket under the HU (because I'm going from double DIN). Not really sure where else to put them. Now I had both digital and analog voltage and ammeters before, but I might not be able to do the analog this time. I would still like to. Here's what I'm working with:
For my tweeters, I'm reusing the Vifa NE25VTS. I will be putting them in the sail panels. I still have to decide aiming, any thoughts? I think I am going to aim both at either the center between the two seats, or opposite headrests. I did the latter in the Blazer and liked it so that's a sure fallback. But I just ordered spare sail panels to play with.
Mids will be Stereo Integrity TM65s. Will be fully sealing and deadening the doors, as well as applying the KHA method of driver treatment, including the foam ring to the plastic door panel. Will be nice to actually fit drivers behind the stock door panel.
For my substage, I'll be running only one Dayton HO 15. Since my seats don't fold down, I've decided to do a 4th order firing through the speaker grills in the rear deck. I will be doing 2 cubes rear chamber, 1.6 cubes net at 54Hz with two 5" ports for the front chamber. Here's the grill I'll be firing through and the trunk I'm working with:
For my amps, I will be running the Soundstream REF2.370 for tweeters, a Ground Zero 4200XII bridged to the mids at 8ohms, and a Ground Zero 2400XII bridged to the sub at 4ohms. Not quite sure on placement, but I think in the trunk what I'm going to do is put all wiring in between the sub box and seat, box right behind that, and then the amps placed vertically in a row (side to side, so looking from trunk like this: = = =) with the rear covers off. Then I'll put plexiglass over the amps, so when all is done, looking in the trunk all you'll see is the amp guts. Plus, I'll still have half my trunk.
Pretty excited about being able to make this look pretty OEM. Only thing that will be different is HU and tweeters.
What's the best cheap deadener now?
Theres not really any cheaper ones anymore.
Knoknoise is pretty cheap
Stinger roadkill
DD SE3.0 EXPENSIVE!
Stp aka black magic
Sent from my draconis using Tapatalk
Stinger roadkill
DD SE3.0 EXPENSIVE!
Stp aka black magic
From what I've heard, Roadkill is pretty good. I've heard mixed things about Knu's stuff, so I'm not going that route. I'm going to take a look at NVX, as well as Noico from Amazon.
Nothing mixed about Knu.
I think what I seen was about their lower end line. I agree kolossus is pretty well regarded, just more money than I want to spend.
Really looking at Noico. They're actually testing it now in that CLD thread.
Imma stay tuned to your build since we have same gen impala
I'm new to the car audio and I got some dimming going on so I'm curious to see what battery and any other electrical upgrades you do
I can tell you right now what I plan on. I will be replacing the front battery with a Sears Diehard Platinum G34. Will be doing the big 3 under the hood, but it's going to be tricky because of the stock ammeter. I might have to do two runs of 4AWG to fit it through there. Will be running 1/0AWG to the rear for my positive, and then grounding in the back for my negative. I have a DC Power 270XP sitting here, but I need to get it recased, which I'm not going to do for a little while. If I need more, I will be adding ultracaps in the back.
Of course, dimming is tricky. A .1V drop could give you dimming. Sometimes you just have to live with it. I think I heard placing one of those .5F-1F car audio caps inline with the headlights solves it, but I never tried that.
let me know how that battery goes i got one from duracell agm plat from sams club it improved my voltage a little.
ill be looking forward to seeing you big three
Oh, Diehard Platinums are real good batteries. I used this same battery, plus a couple G31s, in my last vehicle.
I have a 08 with a mechman 240 ext regulated to 15v duracell 55ah under the hood 2 100ah dekas in back with 4 runs of cca ..i run a aq3500.1 and a ppi bk800.4 and i drop from 15 to 14.2 full tilt...just some numbers for ya..u def wana ext regulate that alt or else u will drop to 12.9 as a starting voltage due to ecm control
gckless
gckless
San Antonio
Umphism
