2009 accord 2.4 mechman alternator need help!!!
I honestly forgot how long it took I believe the website States how long it takes and yes it was a direct bolt on you just have to change the head of the ground wire witch is also provided with the alternator
Awesome dude. Thanks for the info. I have a newish battery. Like 8 months or so. A AGM xpower from batteries plus. It has been a amazing battery.
Did you do the eld bypass?
Sent from my LG-H910 using Tapatalk
To be honest I didn't install my system i took it to a local shop to get the work done with warranty instead of messing around with it myself . I'm running 0 gauge with the big 3 set up that's all I know from the set up I have
That's cool. I thought about doing that too. Thanks for the info dude.
UPDATE- after months of research and countless deadends i almost gave up until i did some math on the length of the belt and found the exact size I needed 7 ribs and all. It eliminated the squeaky rattling noise I kept hearing when I was at a stop the belt brand is bando part# 7pk1815 and hopefully this helps someone in the future
Haha. Mechman just told me I can use the same size belt.
Oh really thats cool i didnt think they would lol but I provided them with the same information so that no one goes through the same headache I went through to make this work
We have the same gen and mine went on with no problem. You must have a V6?
Na his is the 2.4. it's in the OP.
Did you get the same alt? It has a slightly smaller pulley so it would make sense that it would need a shorter belt.
I believe so. I got the 240 on my 2.4 and my mechanic bolts is right on. It took him some figuring but he had it in about 30 mins.
I bought both belts to make sure.
Did yours turn out the way you wanted it?
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
405
A problem may be caused by your phone's or vehicle infotainment systems' software. Be sure you have the latest software version for your phone and...
so, here is what im working with and end goal and working with 100% factory Car 2009 nissan altima 4 door base radio Music style Country rap...
DOOM1987
DOOM1987
New jersey
JDay
    May 20, 2024
    May 20, 2024
