2007 Ford Superduty diesel...????
12volts
yellow (30A), lt grn/pur (30A)
ignition harness
Starter dk. green + ignition harness
Second Starter N/A
Ignition red/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray/yellow and red/black + ignition harness
Second Accessory dk. blue/lt. green + ignition harness
Keysense black/pink - ignition harness
Power Lock pink/yellow (w/o keyless) 5wi driver kick, door harness
Power Unlock pink/lt. green (w/o keyless) 5wi driver kick, door harness
Lock Motor pink/black 5wi driver kick or VSM, gray plug, pin 1
Unlock Motor red/orange 5wi driver kick or VSM, gray plug, pin 7
Parking Lights+ brown + switch or VSM, green plug, pin 2
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org ® + turn signal switch
Turn Signal® wht/lt blu (F), org/lt blu ® + turn signal switch
Reverse Light black/pink + back of fuse box, black 8 pin plug
Door Trigger use dome supervision wire
Dome Supervision black/lt. blue + pass kick or cluster, blu plg, pin26
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT red/lt green or red/yellow ac any ignition coil or fuel injector
Wait to start see DirectFax document 1091
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - switch or cluster, blue plug, pin 18
Horn Trigger dk. blue - switch or VSM, green plug, pin 6
http://directechs.com/techtips/pdfs/resources/security/directed_techtips/1091.pdf
sangerdude
sangerdude
Central Cali
gl0ck
BP1Fanatic
BP1Fanatic
