2007 Dodge nitro amp installation
I have a 2007 Dodge Nitro and need help installing an Amp to the factory stereo. The factory stereo already has a factory amp installed and I just want to add two 10" subs and an amp to the system...but how? Any help would be appreciated...Thx
The factroy amp for that car is to power the sub. You can catch the speaker wires behind the radio harness.
Left Front Speaker (+/-) gray/purple - gray/yellow
Right Front Speaker (+/-) dk. green/purple - dk. green/yellow
Left Rear Speaker (+/-) gray/lt. green - gray/dk. green
Right Rear Speaker (+/-) dk. green/lt. green - dk. green/gray
You will have to use the second starter with a 560ohm resistor on the ignition harness for your amp turn on because the stock amp turn on and radio acessory uses CANBUS.
Second Starter purple/brown - 560 ohms
Aydeezee2002
Aydeezee2002
Las Vegas
Aydeezee2002
Mike Mccabe
