2006 civic SI custom setup .. what do you think
Boostedg35
15
DE
The trunk will be custom fiberglassed next week with a 7" screen and the subs and amps. I chose these amps because they will match the look im going for. the black red and polish accents. also i attached some pics of how i want the system to look and also of how i want some red LED's hooked up to the dome light so they dim out when the dome light dims out. My friend who works in a custom shop is doing all the work on his off time with another buddy so im getting a great deal. the only thing im worried about is weight. i dont want to add to much weight to the car.
Deck:pioneer avic z1
Front speakers:Infinity Kappa 60.7cs
Rear speakers:polk Audio db6500
Front and rear amp:Rockford Fosgate Punch P8004
100W x 4 Car Amplifier
Sub amp:Rockford Fosgate Punch P10002 2 Channel Car Amplifier
1000 Watts Bridged Mono - Remote Bass Equalizer
resize
subs: 2 Eclipse SW7124DVC-T2 - Eclipse Aluminum 12" 900 Watt 2 Ohm DVC Subwoofer's
1. Infinity Kappa 60.7cs, 6.5" 2 way component car speakers (pair)
2 Way 6.5" component speaker design
Includes 2 tweeters, 2 woofers, 2 crossovers
2 ohm impedance
MMD dome tweeter
Computer designed crossover with separate tweeter level control
270 Watt peak
90 Watt RMS
Freq response 85 - 25000 hz
Sensitivity 95 db
Outboard crossover
Tweeter level control
Neodynium magnet
Unipivit tweeter design
2. Polk Audio db6500 6.5" 2-Way Component Speaker (pair)
Impedance: 4 ohms
RMS Power (continuous): 100 Watts
Power Handling (peak): 300 Watts
Cutout Diameter: 5" (12.70cm)
Efficiency: 92 dB
Frequency Response: 40Hz-22KH
AMPS:
1. ROCKFORD FOSGATE P10002 MOBILE AMPLIFIER
250x2 @ 4 ohms, 500x2 @ 2 ohms, 1000x1 @ 4 ohms,
12dB/oct Butterworth HP/AP/LP crossover variable
40-400Hz, RCA inputs, RCA pass thrus, cast aluminum
heatsink, military spec PCB, and remote Punch Bass EQ
with 0-18dB @ 45Hz, H 2.4" x W 11" x L 17.7"
2. ROCKFORD FOSGATE PUNCH P8004
800 WATT RMS 4 channel amplifier
Bridgeable to 4, 3, or 2 channel
400 watts x 2 @ 4 ohms RMS Rated
CEA2006 RMS Rated and tested
200 watts x 4 @ 2 ohms rms rated
100 X 4 WATTS rms RATED @ 4 ohms
.08% THD @ 4 ohms
Variable 40-4,000 Hz Low-Pass + High-Pass Crossover
Preamp Outputs
Signal-to-Noise 80dB
Frequency Response 20-20,000 Hz
Wired Remote Bass Control included free of charge
Bass Boost 0-18dB
Mosfet Power Supply
LED Power Indicator
Dimensions: 11"W x 2-7/16"H x 17-11/16"D
here is an idea of how i want it to look in the end.. a cross between these two
here is how the inside LED's should look
and last but not least.. here is my car..
and heres one of someone elses interior so you can see that the gauges are red
I would get a better set of comps for the front and just a set of coax for the rear.
some pimpin rainbows maybe ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well the rear comps are REALY goin to screw up the sound stage.
and from anythign I have heard the infinity doesn't relaly have that good of lows //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
try out some Rainbows, after reading reviews it will more then liekly be my next comp set.
looks like it will be a nice install, the only thing i don't like is the mixing of two types of component speakers, it should sound fine i just prefer having the same speakers all the way around not counting subs.
For starters is that really your car? I mean why use someone else's car for interior pics. Why not just take pics of your cars interior?
Anyway sweet car if it is yours and some sweet setups. I am not into the whole LED light thing, but to each its own. I mean I could see doing the whole neon, led thing a couple years ago, bit it is fading out now.
yeah the car is really mine.. i dont have any interior shots so i used that one.. im in iraq right now and ill be home in about two weeks.. ill take pics of everything and show you guys when its done..
so put the polks up front and the infinity's in the back? everything is already payed for so yeah..lol
here you go
http://car.rainbow-audio.de/home/home.php?lan=2
There is a dealer on this site (6speedcoupe) not sure ont eh exact spelling of his name however //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif He coudl defiantly help you out
oh everything is paid for...
an lie stated do not put comps int he back they wills cre wup your sound stage. people are tellin you what they think but you do no seem to care.
all the equipment is payed for..
so its really gonna **** with tehe comps int he back? is there a way i can wire them so it wouldnt ****?
Boostedg35
Boostedg35
DE
Boostedg35
