2003 sierra dimming prob.
It sounds like your batteries aren't connected together right? Have you load tested them seperately while there is nothing hooked to them? What batteries are they? Also, you have two wires coming off the alt...1 to your second batt and the stock to your original batt?
um i fixed the radio problem.... the starting battery went dead today and is shot..... so i replaced it with a Newer one and all the headunit problems and the highs not working are gone WOOHOO.... butt the subs cutting out is the final issue i have to solve......
it takes about 15-20 minutes of continuious running for the subs/amp to quit.. then it comes back on for about 10-15 seconds and goes off. repeatedly....and the amp gets really hot
ON TO ANSWERS...
i have 2 wires coming off the alternator
amp batt. Everstart maxx
starting batt. powervolt
Try running a wire from your neg post on both batteries to connect their grounds. They will still power things seperately, but will share their ground. Make it whatever gauge your power wire is.
You may be getting ground loops since you are running two "seperate" batteries. It may not solve it, and like mentioned above, Are you running at proper ohm load?
I doubt a sony xplod 1500w amp can power 2 rockford p3's adequately. Though with xplod amps it will probably die soon anyways, from what I've seen, they don't last long.
Subwoofer Specifications
Subwoofer Size 12"
Voice Coil(s) Dual (2 voice coils)
Impedance (per voice coil) 4 ohms
Peak Power Handling 1000 watts
RMS Power Handling 500 watts
Woofer Surround Poly-Foam
Woofer Composition Kevlar Reinforced Semi-Pressed Paper
Sealed Box Volume 0.75 - 1.25 cubic feet
Ported Box Volume 1.79 cubic feet
Sensitivity 85 dB
Frequency Response 27 - 250 Hz
Xmax (millimeters) 13.4 mm
Top Mount Depth 6.75"
Cutout Diameter 12.75"
amp....
1200W Max, 2/1 Channel Car Amplifier
RMS Power Rating:
4 ohms: 200 watts x 2 chan.
4 ohm: 500 watts x 1 chan.
Max power output: 1200 watts x 1 chan.
MOSFET power supply
Tuned Bass EQ (0-10 dB)
Tri-way capable (Tri-Way crossover required)
2/1 channel operation
Speaker-level inputs with signal sensing for automatic turn-on)
Preamp RCA outputs
Heavy duty aluminum alloy heatsink
RCA level inputs
screw terminals
Variable low-pass filter (50-300 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-20,000 Hz
running a 4 ohm load... but it is double bridged
also the highs going off and staying off.. problem is still here, it did it again this morning
also what is a really good amp for these subwoofers
Subwoofer Specifications Subwoofer Size 12"
Sensitivity 85 dB
amp....
RMS Power Rating:
MOSFET power supply
Preamp RCA outputs
RCA level inputs
screw terminals
Say wut? //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I don't know if this is what youre saying, but it should look like this:
Since both of your amps are turning off, it is some sort of electrical issue.
the subs are wired exactly like that. except where they connect to the amp, i twisted the 2 pos. and the 2 neg togeather and they are bridged.
I only have ONE amp......lol
and the highs are still off and click randomly
ITS DRIVING ME CRAZY!!!!!
jeremy.vaughn
jeremy.vaughn
marion county AL
jeremy.vaughn
Mike Mccabe
