it shouldnt be that bad, just be careful getting it in and it should be no problemabout the only hope, good luck not scratching your tint. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
about the only thing i can think of to try is see if the dealership can program a keyless pad for you with your vin, but i have a feeling that will be more expensive then a window or a locksmith.windows is rolled up tight
yeahbetween the open and shut part
have to keep that in mind lolz if i aint got a coat hangar next time, should be easy ive had to do it on cars where the lock button was facing the opposite door is tuffIve done this many times in my truck
take two LARGE flat blade screwdrivers to the top of the door...be careful not to get the weather stripping ....and very slowly work each screwdriver back and forth moveing them deeper into the door jamb as you pry the door jamb back...go very slow...as to not bend the window frame....then get a long coathanger or I sometime unscrew my antenna and use it
I've had to do this to my truck 5 or 6 times if you got any qustions you know the number
no he wants to get in without paying a **** ton of //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gifwrap ur hand in a t-shirt or cloth and just break the window if ur real desperate to get back in the car!
