2002 explorer keys locked inside
After having to to that 5 or 6 times I finally tapped into the door lock switch at the back hatch and ran a water proof momentary switch and hid it under the chassis. It unlocks the doors but dosnt un-arm the alarm.
Take your titel to the dealership, or at least some proof of ownership with the vin, and they can make you a key. If its a 2002 it shouldnt be too expensive as it probably doesnt have the transponder
not sure what you mean by a transponder but they do have a chip in them for the theft system, keys made at the dealership are like 50 bucks because of that chip, it has to be programmed to your specific car or it wont work.
Ive done this many times in my truck
take two LARGE flat blade screwdrivers to the top of the door...be careful not to get the weather stripping ....and very slowly work each screwdriver back and forth moveing them deeper into the door jamb as you pry the door jamb back...go very slow...as to not bend the window frame....then get a long coathanger or I sometime unscrew my antenna and use it
I've had to do this to my truck 5 or 6 times if you got any qustions you know the number
What have I learned from this?
You lock your keys in your ride way too much, lol!
lmao....twice withinn 30 minutes one time....did you see this post?
use the antenna like other dude said, much easier to push the buttons
It also makes it much easier if you sharpen the end of the antenna so it dosnt slide off the button...just another little helpful tip if you plan to lock your keps in your car or had the habit like I did
911
They do it for free
Locked my work keys in work truck in Florida, i live in Lousiana, called 911....said i locked my keys in my truck...they had a unit out there in 5min
Its common thing they said
Good luck
matrxx dude
TEAM DB UNIT
matrxx dude
tifton ga
Steven206Seattl
