2001 Eldorado Speaker Removal?
Had an Eldorado for a few years with many systems and took it apart more times than you can imagine.
Two 10mm bolts you need to loosen from the trunk to loosen the back seat they are at the top. Remove the bottom part of the rear seat (pops out) and unbolt the seat belts to get the bottom of the back seat loose. Once that is out the rear deck comes out pretty easy if I recall.
As far as getting the speakers to work, leave in the Bose or change everything.
I believe the Bose in that car is built so each speaker has its own amp built in.
As for pics... you can search for some of my oldddd build threads but good luck lol.
I guess you could. I have a old bose speaker from that car laying around I just put on a meter and it read 1ohm so you would be getting 1/4 of the minimal power it put out anyways.
Bettr n' Revrse
I do what I want
Bettr n' Revrse
Grand Junction, CO
Bettr n' Revrse
