2000 Ford Mustang Install Problem.
  • 2
Mr.Strike
I bought a Kenwood deck to go in a 2000 Mustang. I want to install it my self. I got every thing I needed, or so I thought. The guy at the Best Buy install bay said I had to bypass the factory amp. In the Mustang it has the deck with the tape player and the CD player as seperate units. The wire harness I have has two connections one black and one gray. Now, I do not know where to plug up the black harness. I unhooked the factory amp completly. Does anyone know where I can get an install guide specifically for a 2000 mustang with the premium sound package? Thanks in advance.
Im' not sure how the new systems are. There are usually 2 types of factory amps for uses for their sound systems. Depending on which one you have you might be able to get adapters. If not you will have to chop the harness off the amp and hard wire it in. You can use a 9 volt battery to find each speaker. Take it to you local shop and see what they think.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
Mr.Strike
Mr.Strike
Arkansas
Mr.Strike
    May 18, 2024
    May 18, 2024
