2 RD Alphamax 15s in 9 Cubes at 34Hz (Aero, Grand Marquis)
With 23" deep are you gonna be able to drop it in without a problem? A few people have told me to limit to 21".
Build is looking good. Love the Marquis. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Looking good so far. I'm dissapointed that you got the 5k and are only running it at 2 ohms though, hahah.
Where did you get 2ohms from? .5ohm, after impedance rise he will be right around one //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
Yeah, The new box wont be done yet, I need to properly brace it and figure out a way to support the ports.
Call me before you put the subs in I need to talk to you about something for a bit, it will help a lot. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
X2...I know my box is 21" deep and it bearly fits with the sub in. Its gonna be close.
did you put those other speakers in? how do they sound?
I hooked them up to my home system, they work and sound good but they wont replace my ID's if anything Ill run both sets
Thanks, I think it will fit, I measured quite a few times and before I glued it together I fit the bottom board in and it seemed to fit fine....
And remember your 08 is a whale style and mine is aero so the trunk could be different
Ill give you a call later this morning, I doubt your up now haha
The subs are far enough in that they don't add to the length on the edges, Ive measured it a few times, but I guess the true test will be in the next few days. Remember its 23" OD its 20.75" ID, if that helps at all?
Check out post #11 Matt!
Yeah me either //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Oh yeah Ill prolly be on the meter by next weekend, my goals are to bassrace 139.9 and maybe do street c
Amp is a Team Cactus 5k run at 2 ohms
Oh will you? Cant wait to see your new setup...
And I know that sticker is so realistic, I bet everyone on DOA will want one now. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Thought about doing that but I dont think I have the room, maybe... either way I had a 10ft section of 6" PVC just begging to get cut //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Note the BFH lol
Almost Done =)
Looking good.
I know the amp came in //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
how about the sub?
Yep the amp is here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The sub came friday, it fell out of the box in the truck (didnt fall just the box came out around it) when Fedex dropped it off but everything looks ok, hopefully it plays fine.
Check for coil rub, and take a reading... if those to things are fine, im sure your golden. Madison show?
Ok will do, prolly tomorrow Im tired from tonight, freaking sanding and filing to make that rear port brace.
Ill def be at the Madison show and possibly the Zion Show on Saturday. The box should be in tomorrow or Wednesday so I have time to break the subs in //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
great build but let me tell you something if your demoing that thing bro an you smell coils turn it off or down, i know you should know that by now but i have learned that with these subs when i first put mine in an played it till it smelled an turned it back down now it don't smell at all myself.
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
929
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
822
You may need to go to some shows and sound offs/meetings
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
GearGuy2001
GearGuy2001
South Beloit, IL
inkfx
    May 31, 2024
    May 24, 2024
