(2)Precision Power PPI EPX-223 crosover BNIB 175 shipped ea
  • 4
jmw3235
Up for grabs are 2 Precision Power Epx-223 cross overs brand new in box.
pictures are now on my photobucket or i can email them to you
photobucket.com/jmwppi
Specifications:
Dual 2-Way, or Single 3-Way Active Crossover
Linkwitz-Riley 12dB/octave Slopes
Integral 13 Hz Subsonic Filter
Input Attenuation
Detented Frequency Selection Controls
Gold RCA Input and Output connectors
PowerLock Power, Ground and Remote connector
PWM Power Supply
Designed and Handcrafted in the USA
Signal-to-Noise Ratio >102dB
Total Harmonic Distortion (1KHz, 1VRMS) 0.002%
Crossover Slopes: 12 dB/octave
Crossover Frequencies: 50Hz to 5kHz
Input Impedance 10 KW
Maximum Output (10 KW Load) 8 VRMS
Supply Voltage 11-15 VDC
Dimensions 5.125'W
7.020' L
1.813'H
NOTE:Before beginning, disconnect the negative (-) terminal of the batteryto prevent an electrical short to ground. Reconnect the negativeterminal only after all connections have been made.
Looking for 175 shipped for each one.
Shipping free...new here but plenty of feedback on ebay: wrightj18 thanks
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
530
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
391
jmw3235
jmw3235
Hoodstock, Athens
jmw3235
    May 12, 2024
Brendon Jenness
    May 11, 2024
