2 ga wiring kit
well with their kits it only has 17ft so i would need that to a distro and about 4 ft more from the distro to the amp. But its still 1/0 how would i get that into the amp if it fits 2awg.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Because its basically ghetto-rigging and retarded.
To snip down a few strands of wire to make it fit properly? Yeah. . . OK because thats ghetto //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Would be a good idea to get a distrobution block if he's setting up multiple amps but your explaination warrants little explanation of why not. . . . . just my 2 cents
Making it fit properly is using the correct wire in the first place... whats the point of buying more expensive 1/0 wire and limiting it's abilities by cutting it down to jam into a smaller receptacle?
Doing it right the first time will save you time and effort in the long run.
As for the 1/0 to 2ga ... dunno what to tell you. Couldn't find them no Partsexpress or cardomain.
Someone correct me if I'm wrong, but I don't think you need to have 2 awg input. You will be fine with a long 1/0 run to a distro block and then a SHORT 4 awg run to the amp. Just strip off a little extra and fold over the strands of the 4 awg if it doesn't fit perfectly into the 2 awg input on the amp.
2000Gator
2000Gator
Baltimore, MD
patrick1202
