(2) eD NINe.2x SQ amps
wew lad
wew lad inc
Two NINe.2X two channel SQ amplifiers. High sound quality Class AB amplifiers, these things are heavy and rated at 12.5 volts!
I purchased these amplifiers locally from their original owner, he told me they were purchased back when eD was still around and when he became ill the amps went into storage. Up until recently he had forgotten about the equipment and then decided to sell it. Unfortunately I do not have the original boxes but they will be shipped well packaged by a carrier of your choice (within reason).
Amps are fully functional 10/10. They were bench tested with an oscope and a subwoofer.
Cosmetics are 9/10 due to the minor scratches on the amp in normal use locations, I can take extra pics if requested. No scratches on the beauty side of these amps. All set screws are present and function.
Detailed specs found here:https://web.archive.org/web/20060621153526/http://edesignaudio.com/product.php?cid=17&pid=33&tab=Specs&cur=USD
NINe.2X Amplifier Power Ratings
RMS Wattage Rated at 12.5 volts!
600 x 1 @ 4Ohm
200 x 2 @ 4Ohm
300 x 2 @ 2Ohm
NINe.2X Amplifier Detailed Specifications
Signal to Noise Ratio
-95dBA
Variable Input Sensitivity
150 mVolt - 7.0V
Remote Variable Input Sensitivity
Yes
Variable Low Pass X-Over
40-240 @ 12dB
Current & Thermal Protection
Yes
Remote Bass Equalization
No
Variable Phase Control
Yes
Master / Slave Option
No
Efficiency
Variable SubSonic Filter
N/A
Fuse(s)
2 x 40
Max Current Draw
85
NINe.2X Amplifier Size
Length
14.70
Width
9.85
Height
2.25
$170 for one amp shipped
$300 for both shipped
Give me a shipping label or pick it up locally for OBO
see above
check out the eD subs I have for sale! http://www.caraudio.com/forums/subwoofer-classifieds/618725-ed-minty-13ov2-16ov2.html
last one is pending trade, but will still give preference for immediate cash buyer, i'll need to confirm with the person im pending a trade with that he doesn't need it out of respect
wew lad
wew lad inc
wew lad
VA
wew lad
