It may store power, but when the electrical system cant supply the demand the cap will put out its stored energy, and since its very minimal amount the cap will constantly need charging. Causing a drain on the system however minimal you want to look at it. Therefor IMO, it is worthless to have.
How long do you think it takes to charge a cap when inline in a system like a car? Electricity moves at speed of light, your music moves at oh say speed of sound....which do you think can react faster to the music? Unless your are doing stright sweeps a 1F cap will recharge between beats.
From what I have found personally testing, the isolator will keep your starting battery from draining to the point of failure. On the otherhand while running your car will run off its alternator. Adding the isolator will drain a little more off your alternator, and may cause the alt to fail. The up hand is that you atleast know your car will start and continue until you can afford the upgraded alternator.
An Isolator does what it says. It isolates Battery A and Battery B (in rear) from each other with the ALT powering both. With the car on, both are equal. Car off Batt A has no draw (other then standard car acc). Batt B is powering your stereo's amps in the rear and being drained while you sit car off and music on (note your HU may be powered still off Batt A if you do not wire it to Batt B and still causing a small draw)
Now when you start your car and Batt B is very low, Batt A will start the car, but the ALT will not be happy with Batt B being low and will need to work extra to get that one up and maintain Batt A as well.
Running with out the isolator, both Batt A and B would be connected and allow for double the extended play time (assuming they are equal size) and upon start up after the above condition, the ALT sees only one load and it would not need to work as hard as the two batteries combined are not as "dead" as the Batt B alone would have been.
Can you drain your batteries with the car off without an isolator - Yes, you can. But with double the reserve you have double the length before this happens. Buy a third battery instead of the Isolator and you have extended your time even longer. Use a voltmeter to monitor your electrical system and you wont need the Isolator to protect you against a dead battery. I guess you could say the isolator just "idiot proofs" the whole thing.
If your ALT fails, your running on battery only and that will not last you very long. Certainly not long enough to to save for a HO Alt (unless you make a few hundred $ a day )
Nothing really to add here. In another thread you talked about NOT to do this...
I am confused, I have always been Pro- Battery and against Isolators, and some what in favor of caps - this of course in audio related topics.
I would think that they minimal loss of .5v would be better for the assurance that your car will continue to operate (*as lond as you do not totally exceed the alternators reserve output for extended periods.)
.5v is minimal but an ESR of .001 is a strain? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif Most battery specs are based on 10.5V is a dead battery. Removing .5V from a 14.4V system is 1/8th of the usable voltage (14.4-10.5 = 3.9; 0.5V is 1/8 of 3.9V)
