2 channel 4 channel mono?
I'm not sure I understand your question. number of channels basically only affects your choices in wiring. And the numbers of amps you will need or want to use. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by jONnyBOi83 make believe each channel means speaker. so 2 channel means 2 speakers, 4 channel means 4 speakers, and mono means 1 speaker (sub). hope this helps.
Not neccasarily, most amps can be bridged. As long as the impedence is right technicaly you could wire a multitude of speakers to a single channel of an amp. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5...
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
  • Locked
Will trade for pair of 6.5 subs or a single 10 shallow
force fed
force fed
Perth WA
ramos
    May 16, 2024
    May 16, 2024
