2 amps into one ????
ok how would you run an amp and a sub when there is an amp powering 2 fronts and an amp power 2 rear speakers and the deck only has one output or would it even be possible
Ahhhh....this is a bit easier to reply to than your original post.
Running two amps off of a single RCA preout is fairly simple. If one amp or the other has RCA outputs on it just run the 2nd amp off of the 1st one.
If there are no outputs on either amp just get some RCA Y-splitters and feed both amps from the same source.
front amp rca rear amp rca ?sub amp?
is that what you mean
those are all connected fron inputs to outputs obviously from one to the other
A line driver or an equalizer will allow you to take the pair of pre outs on the back of your deck and split them into front/rear/sub outputs with out any voltage loss.
The other option is to use an rca splitter to split the signal to your seperate amps, you will suffer some voltage loss though from your headunit meaning a graeter chance of noise in the system and a need to turn the gains up higher on your amp.
Some amps have a "pass through" built in that allows you to daisy chain seperate amps off of one line, it will appear as as an output beside the input on the amp.
sorry for all the questions i got confused when i treied to figure out if it would be better to use two amps or one 4 channel but is there any way of knowing beforehand if it would work. i had no idea it would be so involved
pablo4429
pablo4429
san diego
jsloan10
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
