Underrated, overrated... How do you know?
Most reputable car audio manufactures are underrated, most lesser known brands are overrated...so if you see an 2000 watt amp for $149, you can almost guess. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Kickers WAYYYY overrated, just put it that way....
Lol j/p from what I hear and have seen Kickers underrated
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
So I can see why companies would overrate a product, but why under rate //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Is it because of inadequate testing equipment or is there some other explanation that actually makes sense?
it's always best to be underrated, if you say amp can do XXXX power into X ohm load at XX.X volts, it better do that, and more for the consumer...or, it should. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ah, ok. That makes sense now //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
Some of it is marketing. Like those older Pioneer PRS amps; IMHO those were underrated by so much on purpose simply so people would drool over them when they looked at the birthsheet compared to the "rated" power. I'm sorry, but you can't "over-engineer" something on accident by so much that every model makes more than double it's "rated" power. They knew going into it that the rated power was severely under what the amps were capable of. And look at what happened, everybody is always like "Man, those amps are awesome because they are soooo underrated!!"
Take a DMM (digital multimeter)
set it to AC voltage, with the appropriate sensitivity
hold test leads to the +, - of the channel being tested
blast tone or music at maximum unclipped level
record highest voltage displayed
multiply voltage by itself then divide by resistance of speaker connected to channel.
for example-
34 volts peak is recorded, channel is connected to a 2 ohm speaker/load
peak volts squared
34X34=1156
divided by resistance
1156 / 2= 578 watts
Peak output recorded as 578 watts, to obtain RMS voltage multiply by .727
578x.727= 420 watts rms
This is NOT the most accurate way to find the true RMS rating of your amplifier, there are a lot variables that are not accounted for when you test like this, therefore this test is only to be used to give a better understanding of what your amplifier is capable of doing.
Take a DMM (digital multimeter)set it to AC voltage, with the appropriate sensitivity
for example-
peak volts squared
34X34=1156
1156 / 2= 578 watts
interesting //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif hope it works that way
anders213
anders213
Singapore
jsloan10
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
