2 amp to one sub
Hey I was just wondering if theres anyway running two amp to just one sub if so then how can I do that ?
I would imagine it depended on the kind of amps(amount of channels, etc) subs do have 2 voice coils I would "guess" that one amp per voice coil, then you might have to put another connector on the box. good question
yes buy 2 strappable amps! Then strap them as noted in the instruction manual. If they are the identical amps but arent strappable and have a subwoofer that is dual voice coil, then yeah you can do that too, but some equipment is going to be needed to make sure the gains are set identical. No 2 identical amps are the same, some put put more wattage than others.
i wouldn't do it, even if they are the same model pritty much no two amps will have the exact same output, then your sub will be getting more power to one voice coil compared to the other.
viebotls
viebotls
Hayward
GMCJimmyslt2000
