2 amp 1 DVC sub
candyman206
I was wondering how do you hook up and amp on each coil. I know everything hasto be set exaclty the same or else! But to set the gains, would i set them with a DMM like in the sticky? What other things do I have to do to run two amps on one sub safely?
i want to be like that steve meade guy
then do yourself a favor and educate yourself like him first //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
most people dont do things just to look cool... they do them because they are educated and know what they are doing and what they are trying to achieve //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Come on Hoss, you KNOW that's not true... ideally it would be, but it's just not...
I know what I want to achieve. Plus I could just strap the amps together but I don't want to spend 40-50 bucks for a sync cable. I am tryin to educate myself that is why I asked the question and not just jumped into it. Man, could you just answer with a more informative answer?
I'm afraid that's not a possibility either...
yeah, do that and you should be fine, hey why not run 4 amps, 2 per coil, more power! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I could do that but read my title I just want 2 T-W-O amps. Plus if I didn't want to spend money on a SYNC cable why would I have the money for 2 extra amps.
Well, it's not something that I would do, but go ahead and give it a shot. As mentioned above, ensure both amps are pushing the same current. Worst case scenario: sub damaged.
candyman206
candyman206
Seattle, WA
candyman206
