amp to alpine cda-9825 wiring question
954runner
just bumpin my music
i just put in an alpine cda-9825 last night in my car. i hooked up my sub to it, and spliced the remote wire in with a blue wire on the harness.
the radio works fine... the sub plays well and everything, but when i switch to CD's, the sub doesnt play. the power led on the amp doesnt come on either.
i also hooked up another remote wire to an amp that is currently not working, so my question is, maybe i didnt get a good connection out of the sub amp's remote wire? is this the problem or could it be something else?
thanks
i actually did the same thing with my 9825 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif, you hooked up to the antenna wire instead of the remote wire.
i believe the remote one is blue and white
switch it and it should fix your problem
~Magick_Man~
http://www.stylestandard.net/oswego/Rooms/RoomComponents/AssetView/AssetCount?qDocID=com.webridge.entity.Entity%5BOID%5BCB6035DA0CFD2E4C82DE919A160F0909%5D%5D&Container=com.webridge.entity.Entity%5BOID%5B3765162C0DE61544B9863D3488A59940%5D%5D
scroll down to page 38 and it shows that the blue wire is for the power antenna lead
and the blue/white one is for the remote turn on.
so if you have it attached to the antenna (which it sounds like you do) switch it over and it should work.
~Magick_Man~
954runner
954runner
Dallas, TX
~Magick_Man~
