2 9515's box help - dodge magnum
There is a local guy here with a single 18" DC Audio level 4 and about 3k doing a 153...........In a Magnum.......of course his box is tuned at 45hz.............I would do the two 12s if your plans are to listen to music decently......
2 12s, done correctly, could beat 153.
Not unless those 12's are in a bandpass lol...my single obsidian 12 spanks my 18 in terms of output when it comes to
Band pass isn't louder, if you put you 18 in 6 cubes tuned to 25 with 150in^2 of port area you will get similar results..
I've done a lot of installs and I've yet to use a bp over a properly built ported box.
if you want more output I can help with a transmission line //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I've done 145-146 legal @25hz with 2 he 10s and a Lanzar 1000d..
I assure you the single 18 will out displace the dual 12s..
Well that makes it a proven fact that 12's play lower than 18's
We need to write this shit down stat.
---------- Post added at 02:17 AM ---------- Previous post was at 02:16 AM ----------
Band pass isn't louder, if you put you 18 in 6 cubes tuned to 25 with 150in^2 of port area you will get similar results..I've done a lot of installs and I've yet to use a bp over a properly built ported box.
That just seems like a waste at that point lol
so much thanks for the words of wisdom papermaker hell yea and a single 18 will save me $$$.....buck i'll be sending a request your way for an 18" design man again thanks everyone
There is a reason the loudest vechile in the world uses 18s;)
Alan Dante did a 183.4 with 12 12" Z series on 210,000 watts in a 6th order bandpass //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
He did do like a 180.2 or 181.2 with a single DD Z 18 iirc.
xxlmagnum
xxlmagnum
CA.COM
Papermaker85
