2 9515's box help - dodge magnum
xxlmagnum
hopefully i can get these monsters in here...two dd 9515i's on two m3a's in the back of my 08 dodge magnum. looking to get 4-4.25 cubes per speaker tuned to 32hz. max dimensions are 21" l x 40" w x 23" h, if i am right roughly 11 cubes before displacement?? can i do this??
There is a local guy here with a single 18" DC Audio level 4 and about 3k doing a 153...........In a Magnum.......of course his box is tuned at 45hz.............I would do the two 12s if your plans are to listen to music decently......
because a decent sized port is going to take up 1.5 cubes of the space you have to work with unless you want to tune it to 50hz.........I just played with the numbers....with 35 hz tune and decent amount of port area you are netting about 7 cubes........you might use aeros and get a little more....
yeah dude kinda want my hatch to close...and no way i can place my m3a's underneath the false floor they would go up in flames real quick....**** im stuck
xxlmagnum
xxlmagnum
CA.COM
Papermaker85
