SOLD 2 35ah batteries, 2 BNIB Crunch GPV15d2
  • 1
ktraughb
I really will post pics on this thread tomorrow. They will just have to be from the old cell phone. Anyway, I have two 12v 35 ah batteries, both barely used. One has screw type terminals and the other has the square thru-bolt terminals. same weight each at 35lbs and basically same size specs. Good little batteries for the price. One is from Long Way and the other is Universal Battery $55 shipped each.
I also have two BNIB Crunch Groundpounder subs, these are the 15 inch dual 2 ohm version, capable of handling 700 watts rms and 1400 max. Good little subs, nothing huge but sound pretty good and get pretty loud. 8 awg push pin terminals. I would like to get $75 each plus shipping on these.
If anyone is local, I have three enclosures for sale. two different ported for 2 12s, tuned to 40 hz, one is about 4.25 cubic feet, the other is about 5.25 cubic feet. $40 for the smaller one, $80 for the larger one. Both very sturdy and have 45 degree corners.
Other enclosure is for 2 15s, tuned to 40 Hz, 6 cubic feet after displacement. Pretty loud and sounds good. This one has 8 awg wire already run inside and out for the Crunch subs that are listed (not them exactly but some other ones i had). It has been painted black, I would like $150 for it.
I realize these pics dont have username but theyre some I already had so figured id throw them up in the meantime.
going to get pics with username for the 15s box and the crunch subs and batteries. cant get to the other boxes right now, theyre in storage, but will be able to soon.
215
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
ktraughb
ktraughb
Louisville, ky
ktraughb
    May 20, 2024
    May 20, 2024
