2 18s soundstream xxx 10000d 4th order 2001 gmc jimmy
joshy629
the wood is not ply wood. it is a very strong treated wood called advantech. they use it on floors in most houses and in almost every structure. very very strong. willl be mdf out the outer baffels though
~vehicle~
2001 gmc jimmy
~equipment~
2 dc soundlab xl 18s dual 1's
soundstream xxx 10000d amp.
2 batcap 2k batts and 2 stinger spv 2150 batts
audiopipe 2k 4 channel to midrange
audiopipe, knu, shok industries 0 gauge wire
200 foot of 14 gauge speeker wire
soundstream xxx 7 band equalizer
stinger digital voltage meter
4 vifa 5.5 mids
2 selinium tweeters
2 pioneer 5.5 mid range
2 pioneer 6x9's
~design~
subs fireing to the side in a 8.5 cubic foot sealed box
the ported chamber is 16 cubes
it will be ported inbetween my two seats with 2 8" flared aero ports
joshy629
---------- Post added at 12:21 PM ---------- Previous post was at 12:21 PM ----------
bye bye sun roof
---------- Post added at 12:22 PM ---------- Previous post was at 12:21 PM ----------
starting false floor
---------- Post added at 12:23 PM ---------- Previous post was at 12:22 PM ----------
tight fit around wheel weld
---------- Post added at 12:24 PM ---------- Previous post was at 12:23 PM ----------
finished floor
---------- Post added at 12:24 PM ---------- Previous post was at 12:24 PM ----------
outer shell. 6'5 guy inside it
---------- Post added at 12:25 PM ---------- Previous post was at 12:24 PM ----------
equalizer and voltage meter wired up and mounted
---------- Post added at 12:25 PM ---------- Previous post was at 12:25 PM ----------
sealed box finished and fiberglasses on all sides and corners 8.5 cubes
the basics of my design. on hole until tommorow other subwoofer is being reconed to and 18 right now will have pics tommorow night or saterday of the subs in and all the equipment
its not plywood. its a treated wood called advantech. they use it on floors in most houses and almost anything. it is very very strong. there will be mdf on the outside as a double baffel though
That avantech is very hard and very solid. Quite heavy though. I got an extra sheet or two leftover from doing a loft. Had considered using it for a box actually.
I spent a lot of the day yesterday grinding down my basket and reconing my sub. Got a deecent amout done though. May have pics late tonight if not tommorow night for sure. Maybe even a video late tommorow night
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
joshy629
joshy629
lawrenceburg ky
joshy629
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
