1999 silverado rem. wire
bryce-man
i found the switched 12 volt wire on the back of the stock radio, but when i tap the wire with my remote wire and turn the radio on no sound comes out.
but then if i disconect the rem wire the speakers fade in and i can put the rem wire back on and my amp will turn on and work till i turn it off and it happens all over again.
i guess my question is .. whats going on and how can i get around it?
i tried tapping into the acc. wire(orange) in my ignition harness but the only wire that gives any voltage is the constant(pink).
your using a stock radio?
you should be plugging straight into a harness if thats the case.....
if your talking about running amps with a stock headunit, just run a breaker switch instead of a remote turn on lead. Feed the amp a constant 12v source line with a toggle switch in between.
bryce-man
bryce-man
beach cities CA
Supergumby5000
michigan born
    May 14, 2026
michigan born
    May 14, 2026
