Setting gains properly and its not loud at all...
MitchZ
I have a Kicker Zx2500.1 pushing 2 - 10" Pioneer premiers (800 rms each)
Note.. Its running at 4 ohms.
So the Zx does 1250W @ 4 Ohms RMS... Correct?
I set the gains properly... sqrtroot of 4x1250 = 70 V
I put in a 60 hz tone and set the volume and everything properly and made the amp pump out 70 V at maximum volume.
So I turned it on and it was QUIET!
My 100x4 RMS speaker amp can pump out more bass...
And when I set the gains my way... (so it clips now and then and the subs smell a bit) the subs rip and bass LOUD. I dont know how many volts its running at....
Its powered properly... Kinetik Hc2400 in trunk. and 0 gauge all throughout.
Any explaination behind all this?
u a 50hz test tone have the HU vol 75% of the way up all zero on the settings on the hu and unhook speakers and set gains like that, and after u set the gains with a 50hz see if anything changes if not set it by ear and then put a 50hz test tone on it and test it and see wat u set it at
also do you have your car running or off when setting gains
My car was running.
I didnt turn all the settings off on my deck... would it make that much of a difference?
I think Swoofer volume = full
And maybe +8dB on the deck bass.
I just threw on the test tone at 29/35 volume. (Usually what I drive around with, no distortion)
Like this was a drastic change...
It went from house shaking bass... to just music with a little thump.
My car was running.I didnt turn all the settings off on my deck... would it make that much of a difference?
set everything on the EQ to flat, 75% volume and 50hz tone like suggested above.
MitchZ
MitchZ
Victoria, British Columbia
helotaxi
