1999 Chevrolet Blazer
Wrapped!
Got some wiring done:
Dem switches:
And just a peek at what it will look like in the vehicle:
What size door speakers will fit in the stock mounting holes?! I am putting new speakers all the way around my 99 blazer and i need to know!!
Stop yelling at me!
Here's the size:
You have about 2" top-mount stock depth, maybe an additional .5-.75" depth with a spacer.
So what size speakers? 6"? Do you think 6.5" would fit?
It's not a standard size speaker. 5.25" or 6.5" will not drop in. Cutout diameter is 5.5", so try to find something that will fit in there or adapters, otherwise you're making your own.
Got this piece done. This will go where the stock tape player was:
Two USB ports for my 80PRS, a PAC LC-1 for the sub amp, and a voltage meter/ammeter. The dremel slipped when I was cutting the lower USB port, so I had to shift the whole block over, pisses me off. But, I think it still turned out ok.
This is where it will go, once I remove the tape player:
@treylittlefield, you wanted to see this didn't you?
gckless
gckless
San Antonio
Tripn88
michigan born
    May 14, 2026
michigan born
    May 14, 2026
