1976 Chevy Caprice
Nor-Cal 707
Premium Member
Premium Member
Hey guys, I recently purchased this Caprice with hopes of restoring it and also installing a nice sounding system.
Currently running:
Kenwood HU
Zed audio Draconia
Zed audio Minotuar
Soundstream Exact 5.25 components(front and rear)
Soundstream Exact 12" subs 2ea.
I have 1/0 running from the front to the back.
My question is, I was getting ready to do the Big 3 upgrade but noticed that the wire coming off the alternator does not go to the positive of the battery, it runs down to the starter.
Would I be able to just add a 1/0 gauge wire from the alt to the battery and leave the existing wire that runs from the alt to the starter?
Hey guys, would I benefit by by adding a XS D3400 to replace the stock battery? at the moment I am running an older Kragen stock battery...
I'd say it's always a good idea to keep a fresh modern battery in your car, particularly when running aftermarket electronics.
With that said, if i were to add a second Minotuar and run each 12" with its own Minotuar, would adding a second battery in the rear be all I would need to run the system without having to invest into a high output alternator?
Depends on your listening habits, but I expect unless you push things really hard all the time you'd be fine. I'm running 8 Minotaur on 4 additional batteries and that seems to hang pretty well... Of course I use a HO alternator but mine doesn't put out a ton of current at idle.
That being said, if your subs are the old school Soundstream the pair will have a hard enough time hanging with 1 Minotaur much less a pair. Also, be sure to not wire them down below 2 ohms. They will definitely go into protect a lot and possibly blow up.
Forgot to say that I will be upgrading to either Sundown or DC Audio subs, I listen to mostly rock but always like the low lows of rap...
Out of the two subs mentioned what option/level of build by either of these companies would work best with single minotuar at first then a minotuar to each sub, paln on building a sealed enclosure...
Was thinking level 3 for DC audio or X series with Sundowns
The Sundown X series sounds really nice. That's what I have in my car right now. They can take a lot of power.
I've heard that DC's have sh*tty soft parts. I don't know if they still do
Nor-Cal 707
Premium Member
Premium Member
Nor-Cal 707
nor-cal, bay area 707
adulbrich
michigan born
    May 14, 2026
michigan born
    May 14, 2026
