18v stable amps?
Just out of curiosity, what are some good 18v stable amps?
I like the DD Z2b, but that's out of my price range right now.
How are Stetsoms on high voltage? They seem to be more tolerant Brazilians
Ive always stuck with regular voltage...I tried the higher voltage route back in the day and it was too much headache ...
Dc ampere American bass b2 to name a few the Stetsoms. Get the older kd model
Was looking at Stetsom......... //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
180
427
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
adulbrich
    May 18, 2024
    May 18, 2024
