18" RE Audio XXX Pictures
takes the 12" about 2600 to move much, so i'd guess the inefficiency of the 18" will be worse. i'd imagine needing something like a zapo 4kw or goliath or something.
Given the same motor, the efficiency of the 18 will be at least 4dB or 5dB higher than the 12".
The moving mass of a cone and air in front of it, be it 12" or 18" is so little compared to the force these motors produce, especially the RE XXX. it doest struggle with an 18" diaphragm. The 18 will require less than 1/2 the power to sound equally as loud.
common sense? think about it, if your motor is no bigger, but your basket is what 60% bigger as is cone area, you have to put more to get more. at least that's what my midget nick tells me.
I think you may be confusing how much power it takes for the driver to reach full excursion as opposed to the sensitivity of the driver as a whole. In the case of two drivers with the same motor, one being a 12 and one an 18, yes it will take a little more power to get the 18 to full excursion because of its slightly higher moving mass. The 18 on the other hand will be more sensitive, simply because it has so much more cone area and not enough extra moving mass to overcome the advantage of so much cone area.
//content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif holy fvcker sh!t man, that 18" scares me. //content.invisioncic.com/y282845/emoticons/hide.gif.2d479cfd917eedfe201353b91522ceab.gif
probably lol. i was so out of it when posting that, stupid stomach virus kept me up using both ends for almost 24 hours.
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif Gross? //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Personally I like that little RE RE 8" sub sitting there! I got 4 of them awaiting install! Of course if I had the space for somehting like the XXX I would do it, but I dont think it would work so well in the CC Truck...haha
Idk if its been posted, but here it is.
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
A Link would be very helpful. Id be interested in taking a look at some gear
227
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
347
kicker06
Umm, I don't pay for food
kicker06
Atlanta & South Carolina
iamamp3pimp
Decebal
    Jun 10, 2024
