16v battery opinions??
what kind of equiptment are you using if u dont mind me asking?
I run 6 D1000s, a DC POWER dual alt set-up and 2 Memphis 4KWs wired to 1 ohm each. Never have any voltage/current problems. Shouldn't though with 6 reserve batts and 2 alts, lol.
lol thats exactly what i wanna do! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif so do the dc alts handle the 18 volts easily?? whats your voltage drop like??
My alts are adjustable from 12-20v, the batts usually sit at 16.8-17.2v. Never seen them go below 16, except when i was running 4, i would get 15.5v. Adding the other 2 fixed that. With the 6 i'm running now, my electrical should support ~12kw efficiently.
whats the hightest you should run your 16v batts voltage wise?? **** dude that is awesome lol i'm only gonna be running a 4500D lol but i was still thinkin bout runnin dual alts
Kinetik are good but they weigh more than powermaster D1000's (56lbs vs 46lbs) and they are not as strong. 3 HC16v batts are equal to 2 Powermaster D1000 batts.
good info //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well Rolls Surrette engineers the largest batteries i know of...
If 846aH isn't enough.. then what the hell are you running?
It's reserve rating is over 1,400 minutes on 16v.
If you going for SPL (which is what most people that use 16 volt batteries in car audio use them for) then aH doesnt mean much.
Powermaster is pretty much the better 16 volt battery.
treylittlefield,
If you have two strong alts that will be fine.
thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif now only if i could find a dual alt bracket for my s10 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
treylittlefield
treylittlefield
Sand Rock, AL
TnT_Sounds
BP1Fanatic
BP1Fanatic
