15s facing the cabin
I'm the same way lol. I might make a small one though. I've been putting off glassing my door panels for too long now. A log would probably motivate me to get started on those too so I can run some 8" mids up front. If I make one then you gotta make one cuz I really wanna see where you're going with your build bro
Yeaa maybe i should. and seeing as i just got this car and its only got 25k on it and is minty as fuck it will be seeing a lot of audio setups. YES it will be walled in the future, i love walls fuck people trying to sit in the back lol. Do the panels mang i know how easy it is to put fiberglassing off. at least for me it is
---------- Post added at 05:28 AM ---------- Previous post was at 05:28 AM ----------
U dont wana do 15s and u dont wana fire port into cabin ..just my experience
Why not? what problems did you have?
cant fit 2 15 and fire into cabin unless u try subs up which is crap ..u just dont need 15s i had a single. dd9515 setup ..didnt last long ..2 12s is the way to go in that trunk
I would go with what the guy with an impala says. General rule is if your trunk is louder up firing or rear firing unsealed, than it is forward firing, then you are best off doing that setup. If your trunk is loudest forward firing, then sealing it may gain some on the meter, but not always.
I've sat in vehicles that can hit 150 from 30-70 hz. Crazy flat response. My car doesn't meter that well, but hurts the ears quite a bit more.
Which means, it follows the general rule. Sounding good and being impressive on the meter is also 2 different beasts.
Well im tuned at 32 so its not a fart box but when u get upwards if 150 sq is a myth lol ...i think it sounds pretty **** good for what it is
---------- Post added at 05:49 AM ---------- Previous post was at 05:48 AM ----------
**** thats moving a lot of air for a trunk set up
Yea its a ****** wind tunnel ..pretty flat across the board
Sound quality in pureness can be quite different than what sounds good to the ear. Most people do not hear the same frequencies at the same levels. As long as it sounds good to you, that is the most important thing.
phemps
phemps
PA
n8skow
