15" SVC Sub with Class D Mono Amp
Ejjman1
So I have an Amp that has (2) +'s and (2) -'s and then on the other side has 2 RCA plugins on the left and 2 RCA plugins on the right.
I have my 15" SVC Sub hooked up to the far left (+) and the far right (-), and was not sure how to hook up my RCA plugins to have the best sound. I was messing around with it but could not figure out which way to have it hooked to sound the best.
Any help appreciated. Thanks!
Pictures of solid audio f10d mono amp for sale - Karachi - Electronics - gulshn
Power Audio doesn't seem to have a site, but this is exactly what my Amp Looks like.
As far as Subs...
XFL 15
I did not think it was DVC at all, but then again, the place that installed the sub did not really know what they were doing.
So assuming that it is DVC, and thats my Amp, how would I wire it?
And assuming its SVC for some reason, how would I wire it? I dunno :S
your sub appears to have dual 4 ohm coils. parallel the coils(red to red)(black to black) and connect to the amp. the amp seems to be a mono amp(not going to get 900 watts maybe 600 rms) and im sure is at least 2 ohm stable. so you should be fine running sub parallel.
he thought it was a single, if you view his sub specs, its a dual.
im assuming audio cable means speaker wire. since its a mono block, it only has 1 channel. the separate positives and negatives are for multiple speakers. just use a + and - and you'll be fine. and follow the diagram supplied above.
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
I would not recommend it if all subs are sharing the same chamber. I myself wouldnt do it at all. I would recommend get or having a tuned...
868
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Ejjman1
Ejjman1
Missoula, MT
grandam888
maylar
    Jun 2, 2024
    Jun 1, 2024
