15" spl recommendations around $400
jake760
OR
I'm wanting to do a single 15 for spl, I'll build whatever ported box will work best, I'm pretty much torn between:
Audioque HD315
Memphis Mojo 15
Fi BTL 15
I'm open to other 15's too.
I've got 1200 at 1 ohm right now. What would you buy for around $400?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
BTL/MT or a new HDC3 when they come out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i have a feeling thats gonna be worth the wait...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well if your only giving 1200 at 1 ohm whats the point in SPL?
I say upgrade your and and sub if you want that. a orion 2500d and a BTL would do the trick.
1200 watts is going to keep you from pushing a real spl sub like the btl, or hd3.
if you are going to upgrade the amp later, than go for either the hd, or the btl other wsie get a sub that will do well off that power.
The mojo is very inefficient.
Since when? In two different drop in tests with only 800 watts, the old Mojo (not the M3 Mojo) was noticeably louder than my old RE SX.
//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
well I'll probably buy another 1206d and run 1200 per coil, on a dual 1 ohm sub, would that push some of these woofers pretty good? also I'm wondering I could just buy 2 more type R 12's for less than these 15's, would three R's be louder with 2 1200w amps? also they would be 2 ohms, how could I wire up 3 dvc 2 ohm subs to 2 amps? 1 ohm stable each. thnx for the offers on the subs but I don't have the $ money yet, I'll be saving for a month or so more to get this stuff. btw, any specs out on the new sub from AQ?
Ill sell you my Incriminator Audio Death Penalty 15" for 280 shipped. Extremely efficent woofer. did a 144 with only round 800 watts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
Highest my car has done is a 156. I have 1200w on highs and recently swapped the mids to pro audio mids. This was a challenge as I find many of...
jake760
jake760
OR
onearmedbastard
    May 18, 2024
    May 16, 2024
