14v battery questions
ThatChevyGuy
sue me, its a ford.
Hello all! I am about to install a small system in my daily. Its an '05 suburban with stock electrical system. I am going to do the big 3 and install a 1200w rms amplifier. From my experience with this era of GM, I'm gonna need a secondary battery to help my voltage. What would happen if i put a 14v audio battery near my amp? Would it charge properly? Am i better off with a 12v? Thanks for any input!
You must not have been around for those 12k posts //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
I'm also wondering why he would ask that.... //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Trolling?
You can run a 14v battery, you should just have a stepdown module for it.
You can also run 14v stock system with some cars without issues.
Some cars will start to have sensor issues in the 16v+ range.
But it can be done.
But it can be done.
agreeded. The cells are 14 volts. as long as its at least 14.1 volts it will work. 16 volts isn't needed.
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
adulbrich
