130+ DB system help
Bass Infection
Wisconsin
I want to make a 140+ DB system for $1000 or less, this is with wires/sub(s)/amp i also want some SQ as it will be a daily driver, not just a burp box. Also, I have been looking at RE audio SEx 12" would these be able to push 140+? I would prefer two twelves
That should be easily attainable. Off the top of the head get a pair of AQ SDC's and a AQ 1200 and you'd be well over 130 in the right box.
Or you could go with maybe DC lvl 3's or Fi Q 18.
How much room do you have?
I have a 2001 dodge stratus, but I would probably fold down the back seats and face the subs towards the front of the car. I would prefer to push around 150 db if possible
So you could probably do a pair of 12"s, with the port off to one side.
the difference between 130 and 150 is ridiculous!
x2 on that.
You'd have to do quite a bit of work to get around 150. 140 could be attainable if you burped it, but probably not on music with 1000 dollar budget.
x2 on that.
I would prefer 12" subs actually, what do you have in mind?
x2 on that.
I've done over 140 with music on 450 dollars
  • Locked
Looking to buy these sir! Pm me - I requested you on IG
476
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
917
16
945
Bass Infection
Bass Infection
Wisconsin
Bass Infection
    May 18, 2024
    May 18, 2024
