Northeast Region 12 Voltz Car Audio MECA Event 4/27/08 Baltimore MD
CT,DC,DE,MA,MD,NH,NJ,NY,PA,RI,VT,WV
i should be able to make that show, yanks you need to go i didnt get to talk to you much at the meet //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yea I know man. You were too busy metering everyone lol.
I'll do my best to make my way up there. I hope I can.
I'll let you know Scott.
iw ill have to give you my email 12voltz for all the shows you are having. i will most likely attend most of your shows. any show and shine i have a show car also
Sweet looks like we will have a good turn out. Team US AUDIO will be at the show, so there will be some serious competition.
Just a Heads up, MECA classes are determined by fusing and cone surface area. MECA allows you to use an external fuse block (MUST BE VISIBLE) within 18" of the amp as a reference for fusing rather than the fusing in your amp. This can be advantageous, because you may only need a 80amp fuse to burp your subs, whereas your amp may have 150 amps worth of fusing. Using the external fuse with a lower current rating puts you in a lower class and makes you more competitive.
Just wanted to be sure everyone was aware. We sell Dynaudio, Rainbow, and Memphis, as well as the usual Mainstream brands. WE WILL HAVE REDICULOUSLY LOW PRICES AT THE SHOW. Be ready to buy, because it is one day only.
Correct for MECA members! This has been a pretty consistant (fair) and fast was to verify classes. MECA members must use AGU, ANL or mini-ANL, AUE, ATC fuses .
For non-MECA members it is still a good idea for our competitions to have in-line fusing ... but it is unreasonable to assume you would have in-line fusing prior to the amp so we have a preferred order: total of on-board fusing on the amplifier, if no fuses then 1/2 the amplifiers CEA rating will be used, if that rating is not available then 1/2 the available the maximum peak rating, if that is not available then 1/2 the published rating, if that is unavailable then 1/2 the theoretical rating is used.... whew so everyone can play even if the dont have an in-line fuse
BUT as 12Voltz mentioned there are serious advantages to proper fusing for non-members too
12Voltz
12Voltz
Baltimore, MD
path2spl
