12" W7 and Excelon X811D???
The X811d should work decently well with it.. Sub should be getting a little above 900 watts from it.. W7s are dual 3 ohm coils right? If so wire it to 1.5ohms.. The X811d puts out a little above 900 at 2 ohms and a little over 1000 at 1 ohm, so it should be getting around 950 watts.. The RMS on that sub is 1000, however I believe it can take a little more..
For the price of the amp its hard to beat!
i think the w7 is a single 3 ohm coil. so if that amp is 900 watts at 2 ohms that leaves you with less than 900 watts. so it will work, but a little more power would be better.
This is still a very nice Deal package for an entry level amp set up for some quality amps for the money...
18
Aslo, if you use your head unit for phone calls, read through the manual so you can set the speakers to use with bluetooth calling to front. Trust...
carguy6702
carguy6702
Dallas, Tx.
aDamJ
maylar
    Jun 2, 2024
    Jun 1, 2024
