12' comp vr's or 10' l5's
I would go with the L5's in a ported box since they are nicer than the vrs plus have just about the same amount of cone area. As far as the amp there are alot to choose from that would power them l5's for around $300. Check out the avionix amps or the tsunami amps from edesignaudio.com , Just make sure that what ever you decide to get that the final ohm load of your subs will work and run stable with the amp and what ever way you try to run them. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Kdubs20
Kdubs20
rochester hills mi
phoneman
