1100 rms wire
Since the n1ne.1 is a 1ohm nominal amp, I imagine sometime in the future you will use it there, THEN, the 4awg you are using right now will not be sufficient. I would recommend with that power running 0/1awg. Also, the wattage really has nothing to do with what awg wire you should use, unless you give us a few other details. What you need to know is the max current draw of the two amps together.
naranjateg
naranjateg
Birmingham,Al
RandyJ
