10w6v2 JL Box
aeon
CA
Hey, I'm going to be building my first box and I got some dimensions off the JL 10w6v2 manual. The size of the box seems just about right to fit inside my trunk. What do you guys think about that box? Can I build a better one or is the one in the manual good enough?
Might want to post the dimentions so we know what they are.
22" x 12" x 10.75" Width x Height x Depth
1.25" x10.5 x 30" Slot Width x Slot Hight x Slot Length
17.25" Port Extension Length
This all came from the manual.
Btw, I drive an acura tsx, going to be running rainbow cmx 265 kicks in the front and the 10w6v2 sub in the trunk. JL 300/4 for the front and 500/1 for the sub
if the site says its what is recommentded use it, but that is set-up for dif things. What are you wanting to achieve?
Check out this site and play with the designs. you can find what you want and at the right freq. as well with your port. It weill also give you the measurements of all the cuts
http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
IMO, I'd go bigger than what it calls for. I always do and have never been let down yet.
okay, after messing around with it a little bit, this is what i got. I don't understand to much about frequencies, but this is what I got.
width: 24"
eight: 12"
top depth: 14"
bottom depth: 14"
wood thickness: .75"
port height: 10.5"
port width: 1.75"
port length: 11.5"
port length 2: 13"
total port length: 27.875
square port diameter: 4.83
square port area: 18.375
square port volume internal: 512.20
square port volume displaced: 530.01
box volume (Ft3): 1.402
box volume (In3): 2423.10
tuned frequency (fb): 33.51
aeon
aeon
CA
aeon
michigan born
    May 14, 2026
michigan born
    May 14, 2026
