1000w RMS?
With lower THD you can get better power output.
I would have got the Cadence myself. It has lower THD, better S/N, greater freq response, better features, power rated at 13.8v (unsure about Audiopipe)
I'm sure the Audiopipe is a good amp for the price, but you get what you pay for in most cases.
Either way he already has an amp, now just need to set it properly.
With lower THD you can get better power output.I would have got the Cadence myself. It has lower THD, better S/N, greater freq response, better features, power rated at 13.8v (unsure about Audiopipe)
you can but its not enough to make a big difference in power output honestly, so nope u have no arguement
so u have the amp on its way, what u wana know bro? i seen u said u have 4 ga that should work fine. if u want u can order some 1/0 wire from knu and go int to a block then have 4 ga to the amp. u need a 50 hz for your subs . make sure all the setings on your deck is flat and your amp is set the same way . u wana go 3/4 on your deck and u need to go from there.you can ditch the bass knob that comes with it.
Actually, it's already here and it's installed already.
Either it's the 100F day or I'm going to need to install a fan cause it runs pretty hot.
I think I need to redo the gain. I did the gain to 31.62VAC without the Bass or Gain Knob. When I connected it, it read close to 21VAC.
SpiderX1016
SpiderX1016
Rosemead, CA
SpiderX1016
NorthFramingham
    Jun 30, 2026
